advice on chips please upgrade after 4 years
he did reply, and not to mean or anything but i dont think to much of that mobo either
oh so he did.
gutted.
and if that's the mobo I'm thinking of, you madre a mistake there as well.
this is why you post before you buy
PC6400 is the best speed for the Q6600 because if you overclock it to 3.6Ghz you can run the RAM and FSB at 1:1.
which of the following boards?
ASUS P5KC AiLifestyle Series iP35 Socket 775 8 channel audio ATX Motherboard
ASUS P5K PRO iP35 Socket 775 8 channel audio ATX Motherboard
ASUS P5K-E/WIFI-AP AiLifestyle Series P35 Socket 775 Socket eSATA 8 channel Audio ATX Motherboard
the place where i have ordered the rest of the parts dont have the board you have listed are any on the above ok?
P5K-E is the best board of that bunch. Very solid mobo.
Right then I think im going to ammend my order to the following below:
Neo2-FR iP35 Socket 775 8 channel audio ATX Motherboard
OCZ 4GB Kit (2x2GB) DDR2 1000MHz/PC2-8000 Memory REAPER X EDITION ENHANCED BANDWITH CL5
Intel Core 2 Quad Q6600 G0 Stepping (2.4GHz 1066MHz) Socket 775 L2 8MB Cache (2x4MB (4MB per core pair) Retail Boxed Processor
Will be using my existing:
8800gt ultra
Titan vanessa cpu cooler
Can anyone recommend a good gaming case, was thinking about the xclio windtunnel or propeller?
i really dont understand the whole thing about buying slower ram which is better? should i go for what i have listed or 6400
last one i promise what about the
MSI P35 Neo2-FR
compared to the last lot?
Probably a bit cheaper, and a good board. Not sure which one will be best for Quad cores.
I'd suggest the Asus will be better from an 'Auto' overclocking point of view, but the MSI will be fine it you set voltages.
Looking like a nice system ;) Best of luck.
or
ddr2/ddr3 mobos dont tend to be that good
not to sound stupid. but what graphics card.
surely your old one was / is AGP and the new set up is PCI_E
I mentioned the asrock boardx initially becasue they are a very godo step up from old style to new> but if you are buying new memmory and new g>card(or have apci_e) then dont touch them
They are ok boards, but have virtually no overclocking capabilities
