Advice on CPU cooler (H150i pro) and 6 x Corsair WW LL120 120 mm Dual Light Loop RGB fans
14 Jul 2019
Hi Guys,
So I am just waiting on the above parts to come before starting my first build. I am curious if you have any advice for the above components when it comes to setting them up or if you have any useful links for an absolute beginner like myself. Everything else in the set up I feel I am comfortable installing but I am quite nervous about setting up the cooler and fans.. I know the 120mm fans (2 packs of 3) will come with lightning node pro but I am unsure if I will need a commander pro for these?
Thanks all
