Advice on fan controllers?
8 Jan 2009
Hi guys im sorry for posting in all the different forums here just trying to do the right thing. I have already purchased an antec 1200 case and would like to know what are the best fan controller units around. Thanks in advance
Sunbeam Rheobus :)
+1 for this. I bought one for about 8 quid. Fantastic value.
No fancy LCD's or brand name but shockingly when you connect a fan to it and turn the knobs up and down the fans get faster and slower :eek: which I'm pretty sure a 40 quid controller wouldn't do any better.
Connects up to six fans as well.
Old sunbeams are 20w per channel and have 4 channels but newer ones have more channel and are higher wattage iirc.
20w per channel means 3 normal fans per channel easily if required :)
Plus fans can be turned all the way from 0-12v not just a limited range like some other controllers i have had.
Be warned though the leds are very bright (on the old model at least) but can be easily modded by recessing them slighty so they arent as bright.
