Advice on first custom loop
26 Oct 2002
Surrey
Hi all,
I'm currently waiting for Dune Pro (New Mac Pro clone) case. It has room for a triple radiator (360mm) radiator at the front and then two 80mm exhaust fans at the back.
I would like to water cool the following:
CPU (Ryzen 2600)
Graphics Card: Sapphire RX580 Pulse (Will probably upgrade to 5700XT successor next year)
The motherboard is a B450 Tomahawk Max.
As the case does not have a window, I'm not particularly bothered about aesthetics. What I really want is for the machine to be as close to silent as possible, even when playing games. I'm not overclocking and don't intend to.
With that in mind, what would be the simplest and most effective solution to achieve this? Currently I'm looking at the following.
https://~ibb.co~/6BLSxdv
https://~ibb.co~/6BLSxdvhttps://~ibb.co~/6BLSxdv
Would this work? Should I consider changing any of it?
I'm not going to buy until/if the case arrives as I want to make sure there's space, especially for the reservoir/pump combo.
