Caporegime
- 18 Sep 2009
- Dormanstown.
I do like the ignoring of the CoD Ghost benchmarks like
show real benchmarks that are accurate in gaming ! there is no difference from 8 vs four fast cores at the moment. you choose to eliminate skyrim because you have a fxwhy because the difference can be 50+ fps from a i5 to a 8 core fx in certain areas lol.
you bring the only benchmarks that favor a 8 core yet we on about gaming !in gaming sorry i5 is better but a amd 8 core is adequate and a decent performer. there are no games that show a real gain from a i7 to i5 so its all down to budget at end of day.
as said 8320 and oc or i5. be happy both are different.
Welcome,
Firstly intel vs AMD is a tough choice.
What are you using this PC for? Gaming and if so what games are you playing? and at what resolution?
Aswell you've gone for some odd CPU choices, id suggest you look at deciding between these two instead:
YOUR BASKET
1 x Intel Core i5-4670K 3.40GHz (Haswell) Socket LGA1150 Processor - OEM £169.99
1 x AMD Piledriver FX-8 Eight Core 8320 Black Edition 3.50GHz (Socket AM3+) Processor - Retail £119.99
Total : £299.58 (includes shipping : £8.00).
The 4670k is on the Haswell socket, it is overclockable. While its more expensive it's a better all rounder than the AMD CPU.
The 8320 is basically a 8350 for £30 less (bargain). There is VERY VERY little difference to the 8350, so its a much better buy.. The 8320 will like multi-threaded games like BF4 (it performs a little better than the 4670k in that) but will nose dive in games like Skyrim..
Though it is better for heavy video editing.
Like i say, its down to you're uses and the budget for other components like GPU's and SSDs
So, you're ignoring this little snippet ;
Said Doomed.
When Aston villa went from 2-0 to 2-2, would you not call that a collapse?
Same type of situation in a different area.
A load of old poo.
Firstly - yes it will happen overnight. Two consoles show up with 8 cores, games immediately get 8 core support. It's as crushingly simple as that.
Last generation consoles supported 7 and 8 threads respectfully, they made such a difference didn't they? Oh wait..... they didn't.
And console may have 8 core CPU's but let me explain a few things which you obviously don't know
1. They're only clocked at 1.6Ghz which means they have the same IPS as a quad core running at 3.2Ghz, a single FX 4300 will offer more through put as it's clocked much higher and thus offers higher IPS
2. Games will not and do not have access to all 8 cores
3. These cores, as already been proven with developer interviews will not be used for pure CPU related tasks, they'll be used for culling and other things which means actual core count on the PC side will be even less important
What's poo though is how you speak about an AMD not being able to run games unless all of them are being used. This is utter rubbish as I showed you the other day. Stop making off the cuff remarks on forums and make sure you have the data to back up your claims. Remember Arma III? that's exactly my point. There you were saying how they suffer really bad on an AMD yet the reality was actually the complete opposite.
AMD tanks in the ARMA series, the engine is single threaded, get over it already...
So you've gone from AMD being completely useless for everything, to AMD only being any good when all of them are supported.
Would you go care to go through my history and show where I've said AMD are completely useless?
So far, using engines designed for the consoles we have - (remembering that game devs got the console spec, blueprints and dev kits long before the consoles were released)
Far Cry 3. Uses 8 cores.
"The good news for folks with Piledriver-based processors is that the FX-8350 is nearly as quick as Intel's Core i3-2100 (never mind the fact that the Core i3 costs $90 less)"
"Like most of today's games, Far Cry 3 can use four cores or threads, so it's no surprise that dual-core chips suffer, as evidenced by the Phenom II X2 and Athlon II X2. However, core/thread efficiency is also extremely important and this is where the Intel has an edge, with the i7-3770K and i7-3960X topping our chart."
Metro : Last Light. Uses 8 cores.
A 4 generation old 2.6Ghz i7 920 matching an FX8350?
Crysis 3. Uses 8 cores.
Not bad, but Intel is still faster....
COD Ghosts. Uses 8 cores.
If this game uses 8 threads like you claim why is the 3 generations old 2500k beating the FX 8350?
Battlefield 4. Uses 8 cores.
Core i3 1fps behind the mighty FX 8350?
You're getting far too emotional Cat.
That's good that rage performs better on an FX8150 than an i5 2500K. (Well, whatever those benchmarks show, which isn't actually frame rate, the only FPS I can see is from Tom's which show a complete GPU bottleneck........)
The next Elder Scrolls game (Ignoring the MMO I have no interest in) may very well be a better threaded engine, and probably going down the path of showing outright parity.
Its the megatexturing benchmark,as idTech5 uses such tech. Its a form texture decompression on the go IIRC.
I've been reading up on Rage, and it just seems to scale the IQ to get 60 FPS?
Hmm could have predicted dg and martini in this thread.
To cut it short, apart from the chasm of performance difference people like martin claim between the processors the reality is there is a pubic hair width. The guy has had possession of both systems yet doesn't post any findings as he knows there is little. He hides behind the "I didn't have time to test them". Until he posts something of sound proof I will continue to skim over the weird dislike he creates about the brands (or the people with the brands).
Lets not forget - if you want to play games AND stream the Intel 'nosedives'...
AMD wins that one just check Tek Syndicate.![]()
The problem being is that when proof is posted AMD fanboys start crying and saying it doesn't count or it's unfair....
I remember when I posted my Crysis 1 results.... man the lame excuses and crying the AMD boys did was laughable and pathetic.
WTF are you bringing an old game like that into this for? In fact what rock have you crawled from under?
Theres plenty of fan boys on this forum. You have just held up the intel flag, I dont care who you like but threads like this that put down the FX when typically the poster has never used an FX is pathetic.
