grit the road.
What will that do?
Gritting needs to be done before the snow or frost falls.
It also needs vehicular traffic to make it work.
grit the road.
no it doesn't. work when i did it earlier. it funny watching people trying to drive up there drive covered in ice while my drive is perfectly clear after i gritted it. people are just lazy.What will that do?
What will that do?
If you have an old car, careful use of the handbrake will allow you to apply some braking effort while leaving the front wheels free to steer.
ABS is supposed to do this for you but IME ABS systems dont seem to cope very well with snow/ice conditions.
Of course, if you have an EPB you dont have this option.
Explain to me how a FWD car will go uphill better with the rear brakes slightly applied?
He wasn't suggesting it would help climbing a hill.
OK, tell me how it will help in normal driving?
Uphill is worse for sure, but when the drive wheels are struggling already adding drag to the rear with a handbrake just makes them more likely to break traction and cause the front wheels to struggle.
The only thing you can do successfully with poor traction is use the highest gear you can and be as smooth as possible with no sudden actions which might break traction.
If you are driving for example a RWD Mk1 escort the handbrake MIGHT help avoid spinning but more likely, once the torque overcomes the brake it can cause the wheels to instantly spin, especially if the handbrake is not equal on both sides of the vehicle and it doesn't have an LSD.
For these types of cars, additional load in the boot can help with RWD traction, 4-5 paving slabs should do.
If possible, reversing a FWD car uphill will give more traction.
You've got the wrong end of the stick. He wasn't claiming it helps traction to get going; he's talking about braking.
The handbrake only brakes the rear wheels, so you can apply some braking force without risking locking the front wheels and losing steering input.
Winter tyres as mentioned would probably get you going, but my experience of them is that they can't do too much on compacted, icy tracks (still better though).
Indeed.
I have successfully used this technique for both hill descents and for reversing back down hills that I was unable to climb.
You do need a sensitive touch however.
ABS will allow steering too, even if they lock (obviously if the car has got it).
Absolute nonsense.^ As many have said, Winters help in fresh snow and on cold tarmac, but if there is compact snow or ice on the roads it won't do diddly.
I was driving like miss daisy the other day and turned into a road which was black ice. Winter tyres, AWD and still just slid - zero traction, nothing you can do without metal studded tyres. ABS and steering was useless until my vehicle came to a stop ... by hitting the kerb and wrecking my alloys, suspension and steering rack.
