- 22 Aug 2009
Hullo
I am after some advice regarding a custom cooling for a Corsair Crystal 280x. This is my first ever build.
I am currently looking at the following components:
Case - Corsair Crystal 280x
Motherboard - MSI B550 AM4
CPU - R7 3800X or 4XXX
RAM - Corsair 32GB
SSD - 1TB M2 PCIe 4.0
GPU - EVGA 3080 Hydro Copper
Water-cooler Components:
Reservoir/Pump - Corsair XD3
CPU Block - Corsair Hydro X
Radiators - 280mm x 2 (?)
I plan on using two 280mm Radiators, one on the top and the other on the bottom. The XD3 fixed to the back of the case. As this is my first attempt at a custom build I am thinking of using soft piping.
Is the case good for such a build, I am open to recommendations for a different case.
Any advice will be greatly appreciated.
Regards,
Krupi
RAM - Corsair 32GB
Regards,
Krupi
