- 22 Aug 2009
I can respect that, it is a concern for me too
I am leaning towards a similar system as this...
https://www.tomshardware.com/features/lian-li-pc-o11-dynamic-space-grey-pc-build
What do you chaps think of it?
Might go for a larger rad up top.
Thanks for sharing that Wookie.
Out of interest, do you forsee any complications using soft tubing and a front distro plate?
, careful planning of the loop and you'll be good to go, just dont have any tubes crossing over each other as that does look messy
Thanks I have scetched up the route a few times already.
Unfortunately I now find myself torn between soft and hard plumbing![]()
, soft tubing will be cheaper than hardline, but hardline looks the business once done
, i prefer soft tubing as its far easier to work with. From what i remember, the whole point of distro plates was to ensure straight running lines. As the holes in the distro plates align with the components on the board. Obviously you don't need to use it this but thats the whole point anyway. You'll be able to use it just like any other reservoir/distro system.Thanks for sharing that Wookie.
It's very secure, no lines have ever popped out and i move mine from upstairs to downstairs quite a lot especially these past 2 weeks for maintenance and re-runs, anticipating 3000 series release. I tend to go with the triple seal oring fittings from XSPC, they're very tight and don't let go.How secure do you find your Hardline Jay?
Would you be happy to move the PC around the room/house without the tubes popping out?
2. Who makes the best fittings for either soft or hard? I am leaning towards the EK Range at the moment.
, i have 6 fans which are arranged as intake from the bottom and the top set exhaust out the top, heat naturally rises
