Advice on SSD compatibility please
5 Nov 2009
The home of Rugby League
Hi
About to upgrade to Windows 10, buy an SSD and then reinstall Windows 10 onto the SSD. Been out of the hardware loop for a while so would just like some reassurance before I click through in this one.
My mobo is a Gigabyte H61MA-D2V in an OCUK prebuilt system. Its a couple of years old now and I just want to check that it will be ok with this
https://www.overclockers.co.uk/cruc...lid-state-drive-ct240bx200ssd1-hd-060-cr.html
The Gigabyte website says:
'4 x SATA 3Gb/s connectors supporting up to 4 SATA 3Gb/s devices'
Does that put a limit on the type of SSD I can buy? Will the Crucial one above do the job?
Using Speccy, my current HDD has these details
ST500DM002-1BD142 ATA Device
Manufacturer Seagate
Heads 16
Cylinders 60,801
Tracks 15,504,255
Sectors 976,768,065
SATA type SATA-III 6.0Gb/s
I can't afford to upgrade the mobo
Cheers
