I thought that but then surely it would give me false reading on all my equipment
eek
, if it's just warm to the touch you know it isn't for whatever reason.It may just be a foible of the software you're using or if it was a faulty sensor then it would only affect that drive.
Just touch the SSD while it's running.
If your skin blisters the reading is correcteek
HD tune Pro shows my SSD as being -128 degrees Celsius so im not sure that works...
further reading suggests that most SSD's don't even have a temperature sensor and not to worry about it at allMy Samsung F3s are 29 and 30 degrees, so yeah the SSD sensor isn't working at all.
Its a Crucial c300 64gb
Tried CPUID HWMonitor?
