- 9 Jun 2004
- London, England
Perhaps this belongs on the 'General' board...?
Hi guys,
I've been out of the loop a while, so need some advice on a possible upgrade. Have currently got an Asus P5W-DH motherboard, 2x1GB of G.Skill HZ PC6400 DDR2, E6600 and 8800GTX. Am running Windows Vista x64.
Since buying Crysis the other day, I've come to the conclusion I need to upgrade some of the parts. So far I've picked up another couple of gigs of the same ram. Now I'm considering a quad core CPU, since they're on the cheap side. I understand my current motherboard will support it, but should I consider upgrading it to another one?
Am currently running my E6600 at 3ghz no problem, all air cooled (CPU using an Arctic Freezer Pro 7, which I'm assuming I can reuse on a Q6600?). Not too interested in difficult to manage/maintain overclocks, but happy to go for easy ones (3ghz with a dual-core Conroe was easy to attain with my current setup).
And advice?
A festive 'taaa' in advance
Hi guys,
And advice?
