Not entirely true - by putting more volts through, you speed up electron migration in the processor and fasten its degredation.
However, are you sure that you're putting this many volts through the CPU? Without decent watercooling / phase cooling, your temperatures would be through the roof! Have a look at the VCore figure in the BIOS - I would imagine that this is merely a mis-representation in Windows. My board does this as well, reporting a VCore of 1.4V as 1.792V in Windows.
What is your setup and what temps are you getting reported?
// EDIT // Beat me with the temps. That load figure is just fine. It is impossible that you're putting 1.66V through if you're getting those temps on air. Take a look in the BIOS.
Have a look here. You should be able to get that without raising VCore that much. Take the data there with a pinch of salt - the results are prone to idiots (e.g. e-6 did not get 6GHz out of his!).
What cooling do you have there? Some of the higher positions in the table are using dry-ice and phase change cooling with voltages not that much higher than yours.
