advice please. uk version question
18 Oct 2002
bought the Remastered Beatles 13 cd+dvd Boxset recently, it had a dvd doc disk that does not play in my dvd player, this plays abs every type of dvd,.
i put it into my pc and it plays, but at the start it comes up with Japanese or Chinese text which i found odd.
i then double checked outer sleeve and noticed it had Nstc region 0.
everything is printed in english
was i sold an Amercan Import version ?
Region 0 means region free. NTSC is simply the video format/resolution at which it plays. Pretty much all UK DVD players, unless they're absolute tosh (or a PS3, might I add - not sure about UK ones, but US ones will only play NTSC coded discs, even if they're region free!) should play them without a niggle.
Overall, though, yes it is an import version. Where from, it would be hard to say as many regions of the world use NTSC playback for video.
