- 22 Aug 2003
5 years ago I spent a 'tidy' amount of cash on a watercooling system with the idea being to have a totally quiet well cooled system
well I got a well cooled system but sadly it was never quiet with the pump and fans making it far noisier than the stock air solution!!!
anyway to cut a long story short the kit I bought and still have was a selection of Danger Den stuff for a Intel Pent 5 build (I took it out after about 2 years) the noise was killing me
the pump I have if I remember correctly is an enermax it came in two flavours at the time forgotten off the top of my head its correct name
its boxed up in the garage for the last couple of years but no way is it going back in
the Radiator is a doubled up one and I still have everything
I am just about to start a new build and was going to stick with the stock cooler but after reading all you guys doing it am wondering if I should buy the extra bits to get this setup working again
so my questions are will a water block for a pent 5 fit a current Intel Z77 mobo
and which pumps are extreme quiet these days - no way can I go back to how it was in the old days its got to be whisper quiet or totally silent if possible
another question on my pipes I used the old fashioned jubilee circlips to tighten the pipes to the barbs
on these new one's I see in the gallery in this forum the connectors look to be a far better looking and simpler solution to what they used to be like when I set mine up so how exactly do they connect to stay water tight
they look great by the way
so in essence any help at all to transform my old kit into a new quiet super duper kit I feel pretty sure my water block should be fine if the screw holes line up and I see no reason why the radiator should not be put to good use
so all answers will be greatly accepted Please
regards
Chris
regards
Chris
