Hi,
Currently I'm running a 5yr old Intel core 2 6420 @2.23ghz with 2gb RAM & a 256mb gfx card, its getting rather slow so I'm thinking bang an extra 2gb in there or start over...
If I start over I'm looking at one of the following..
Intel Core i5 3570K 3.4GHz Socket 1155 6MB Cache
Gigabyte GA-Z77-D3H Socket 1155 VGA DVI HDMI 8 Channel Audio ATX Motherboard
EVGA GTX 650 Ti SuperSuperClocked 2GB GDDR5 Dual DVI Mini HDMI PCI-E Graphics Card
8GB DDR3 1600Mhz
OR
AMD FX-4 4100 Black Edition 4 Core 3.6Ghz Socket AM3+ 8MB L3 Cache
Gigabyte GA-970A-DS3 Socket AM3+ 7.1 Channel Audio ATX Motherboard
Sapphire HD 7850 OC Edition 2GB Dual DVI HDMI DisplayPort PCI-E Graphics Card
8GB DDR3 1600Mhz
Now, assuming the 2gb upgrade on my current beast is a waste of time, can you offer me some advice on which of the above is best to go for & also any advice on PSU & casing for the above would be greatly appreciated.
8GB DDR3 1600Mhz
OR
8GB DDR3 1600Mhz
