Hi.
I just purchased a UGREEN NASync DXP4800 Plus. I can only get a 1Gps connection which I think is caused by my router. The Virgin media 3.0 hub.
I have ordered the 5x Hub which I gather should support the 10gps speed. I have also ordered a Cat 8 cable, over kill i know but at £20 for 10M I am not complaining.
I have also connected the NAS to my router with the supplied cat 7 cable which are both downstairs. I run a cable cat 5 i think it is from the living room upstairs to my bedroom which is where I have my main PC. The cable goes into a Netgear GS108 switch which I gather does not support the 10GbE speed either. I plan to change that cable for the cat 8 one purchased.
This is where I need help as I think this will be the bottleneck after the router has arrived.
Can you guys recommend a switch that is upto the job and also advise me if I have missed something.
