Right ive got a build idea in my head, and ive decided to use water cooling (my first time)
There are a range of problems so need something that solves them all.
I'll be running a Q6600 @ max overclock
1) Case size, im going for a SFF Lian Li V350 (when it comes out over here) or a V300 with more modding to do.
So i need some advice about what Blocks, Barbs, Tube's etc to use. budget is slightly limited but still want good components.
Thanks for reading and any advice given
StevenG
Radiator Size must be under, 273mm x 120mm x XXmm
MagiCool 240 Radiators fit the bill, can only get the UV Blue one in the uk, unless someone else can find the black one available in the UK
2) Case size again - i want a res+pump combo or a res and pump that will fit into the height of 2x5.25" bays but MUST be smaller than about 120mm (so no full size 5.25" res's or anything like that.So i need some advice about what Blocks, Barbs, Tube's etc to use. budget is slightly limited but still want good components.
StevenG
- site says end of november...)
