- 2 Jul 2020
Okay so im buying a custom PC from Overclockers Uk. (before anyone says build myself, dont fancy it with screaming kids running around xD)
The PSU they use in a lot of them and that theyve selected for mine is a Kolink Classic Power 600W 80 Plus Bronze Power Supply. Never heard of them before, From what i can gather theyre German built not chineese junk, But ive also got my concerns having never heard of them. The PC comes with 3 years warranty. So on one hand i doubt theyd use them if they had a lot ot issues as its just gonna cost them in time and money for fixing machines... Does anyone know of these and should it be safe enough to not kill my PC?... Id upgrade it to another but 1) Im maxed out on what i can spend and 2) like it seems like almost every PSU is out of stock atm the only others they have in like corsair are overly expensive any way more than i need. I did find a be quiet pure power 11 600w 80plus gold that i may be able to swing if itd really make a difference. or would the Kolink be fine? 0 experience with them, Ive found a couple of reviews on google that seem positive but 7 reviews isnt a lot of info...
Not sure if it really makes any difference but im going of a Ryzen 3700x with a 2070 SUPER.
, I would go for something from SeaSonic or Superflower.
let alone at a price point i can afford
