- 9 Apr 2012
Is there a foolproof way to tell the difference?
Affect causes effectIs there a foolproof way to tell the difference?
Like how an effect affects things?Affect causes effect
Simples.
it was the person throwing the ball that effected the outcome.
^Affect causes effect
Simples.
I've always thought of Affect as being an influence over something, whereas Effect is the decisive outcome.
Like if you're walking a tight rope over a pool filled with sharks, your walk would be "affected" by the presence of the sharks below. However if nearing the end of your rope walk somebody throws a beachball at you which makes you fall into the pool of sharks, it was the person throwing the ball that effected the outcome.
I don't know if that's correct but I've always thought of it that way.
This. effect can also be a verb.yep, learn the meanings of the words and then use them appropriately
verb
- cause (something) to happen; bring about. "the prime minister effected many policy changes"
I've never understood why people don't know the difference between those two words. There are many other examples like this too;
Learn / Teach
Lend / Borrow
Brought / Bought
Either / Neither
etc. etc.
Learn / Teach
Lend / Borrow
Brought / Bought
Either / Neither
etc. etc.
Either of you make any sense to me.Would you borrow me 5 minutes to learn me how to use all these words? I bought my notepad with me
