After a bit of help with PHP
10 May 2007
Kent
Hey guys,
Am trying to make a script for work to save us some time and I'm having trouble. I'm trying to pull data from a text area for multiple SQL Select, and then display the data.
I'm at a stand still as I've been trying for the good part of 5-6 hours to get it working. As you can see, just a basic form / display, but it only displays the first number. And then has the first 2-3 sets of numbers in the array but doesnt display them properly. I'm going to guess its a silly error but I'm pretty tired ATM. If any of you could spot it I'd be in your debt :)
Code:
require("dompdf-0.5.1/dompdf_config.inc.php");
require("include/config.php");
if (isset($_POST['textarea'])) {
           $text = explode("\n", $_POST['textarea']);
for ( $i=0, $size = count($text); $i<$size; $i++ )
	$mydata = $text[$i];
	$sql = "SELECT * FROM company WHERE AccID= '$mydata'";
	$result = mysql_query($sql);
	echo "<table border='1'><tbody><tr>\n";
// Acc Id //
echo '<th>
Acc No
</th>';
// Company Name //
echo '<th>
Company Name
</th>';
// E-Mail //
echo '<th>
E-mail
</th>';
// Acc Manager //
echo '<th>
Acc Manager
</th>';
// PDF //
echo '<th>
PDF
</th>';
/// Search Results Displayed ///
   if ($text !=NULL) {echo "<h3><font face='Verdana'>Search results for $text[$i]:</h3></face>"; }
   for( $i = 0; $row = mysql_fetch_array($result); $i++ )
  echo "<tr>";
  echo '<td><a href=companyinfo.php?AccID='  .$row['AccID'] . '>' .$row['AccID'] . '</a></td>';
  echo "<td>"  .$row['Customer_Name'] . "</td>";
  echo '<td><a href=mailto:'.$row['Email']. '>'.$row['Email']. '</a></td>';
  echo "<td>"  .$row['Acc_Manager'] . "</td>";
  echo '<td>PDF:<a href=http://myurl.dompdf-0.5.1/dompdf.php?base_path=..%2Fdompdf-0.5.1%2Fwww%2Ftest%2Fvoucher.php&input_file=..%2Fdompdf-0.5.1%2Fwww%2Ftest%2Fvoucher.php>'.$row['Customer_Name']. '</a></td>';
  echo "</tr>";
echo "</tbody></table>";
exit();}
Your using the variable i inside a loop which is also using i. Use j or something else in the nested for loop. Alternatively replace the second for loop with "while ($row = mysql_fetch_array($result)){}". As a side note, you should always ue the count function outside for loops as its evaluated for every iteration of the loop which is detrimental to performance.
I think I have far too much time... here's a re-written example. It should ward against dodgy input and because I'm anal it's XHTML strict compliant :o.
Results:
Code:
PHP:
<?php
// Form submitted?
if ( $_POST['ids'] ) {
	// Split IDs by new line
	$arrIDs = explode("\r\n", trim($_POST['ids']));
	// Filter through the list of IDs to remove bad entries
	// assume only numbers allowed
	$arrFilteredIDs = Array();
	foreach ( $arrIDs as $ID )
		if ( is_numeric($ID) )
			array_push($arrFilteredIDs,$ID);
	// Convert IDs into a comma separated list for MySQL
	$IDs = implode(",", $arrFilteredIDs);
	// Connect to mySQL - use your own settings etc here
	$link = mysql_connect ("localhost", "root", "ilikehorses") or die (mysql_error());
	mysql_select_db ("test", $link) or die (mysql_error($link));
	// Execute query - sprintf just allows us to format strings nicely
	// uses mysql_real_escape_string to prevent naughty things
	$mysql_result = mysql_query (
		sprintf("SELECT * FROM company WHERE AccID IN (%s) ORDER BY AccID", mysql_real_escape_string($IDs, $link)), $link) or die (mysql_error($link)
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN"
    "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en">
<head>
    <meta http-equiv="Content-type" content="text/html; charset=utf-8" />
    <meta http-equiv="Content-Language" content="en-us" />
    <title>Meh</title>
	<style media="all" type="text/css">
	h1 {
		font-size: 1.4em;
	fieldset {
	width: 165px;
	textarea {
		background-color:#FFFFAA;
		height: 120px;
		width: 150px;
	table
		border-color: #600;
		border-width: 0 0 1px 1px;
		border-style: solid;
	th,td
		border-color: #600;
		border-width: 1px 1px 0 0;
		padding: 4px;
		background-color: #FFC;
		width:200px;
	</style>
</head>
<body>
<form method="post" action="">
<h1>Search</h1>
	<fieldset>
		<legend>Multi ID search</legend>
		<p><label for="ids">IDs (one per line):</label></p>
		<textarea id="ids" name="ids" rows="8" cols="16"><?php if ($_POST['ids']) echo trim($_POST['ids']); ?></textarea>
		<div class="clear"><input type="submit" value="submit" /></div>
	</fieldset>
</form>
<?php if ($_POST['ids']) { ?>
	<h1>Search Results</h1>
	<table>
	<tr>
	<th>Acc No</th>
	<th>Company Name</th>
	<th>E-Mail</th>
	<th>Account Manager</th>
	<th>PDF</th>
	</tr>
	<?php
		// Get results
		while ($temp = mysql_fetch_array ($mysql_result)) {
		<tr>
			<td><a href="companyinfo.php?AccID=<?php echo $temp['AccID']?>"><?php echo $temp['AccID']?></a></td>
			<td><?php echo $temp['Customer_Name']; ?></td>
			<td><?php echo $temp['Email']; ?></td>
			<td><?php echo $temp['Acc_Manager']; ?></td>
			<td>Code it yourself :p</td>
		</tr>
	<?php
	</table>
<?php } ?>
</body>
</html>
Let me know if you want anything explaining.
Ladforce: Ah, see that now. Will remember for future. Thanks :)
Pho: Just went through the code, amazing mate. Can't believe how quick it is as well with my database with ~100,000 records. I have got the PDF export to work aswell now, was pretty tricky but seems to be working as intended. One thing though I have found atm is that I don't think it says which AccID's is doesn't find. Is it possible to show if it doesn't find any? That would be extremely helpful.
Cheers mate, thx a ton.
You deserve kudos for spending the time and effort to do all of that! :)
It's always good to keep my PHP skills up to scratch as I don't use it much at the moment :D.
The reason it's much quicker is that you were executing a new query for each search string, i.e. if I searched for:
1111
2222
3333
nnnn
You would run:
SELECT * FROM Company WHERE AccID = 1111
SELECT * FROM Company WHERE AccID = 2222
SELECT * FROM Company WHERE AccID = 3333
SELECT * FROM Company WHERE AccID = nnnn
And so it would have to go and search over all your records for every AccID you entered (unless you had indexes set-up on the AccID column in your database, which should speed it up even more).
Using IN we can pack it all into one query, so it now becomes:
SELECT * FROM Company WHERE AccID IN (1111,2222,3333,nnnn)
Which (I think, I don't know the inner workings of it) would only have to parse your records once.
I thought listing what it hadn't found when I was writing it but didn't get around to doing it. This probably isn't the best way, but try this:
PHP:
<?php
// Form submitted?
	// Found IDs in database array
	$arrFoundIDs = Array();
<head>
    <title>Meh</title>
	h1 {
		font-size: 1.4em;
	fieldset {
	width: 165px;
	textarea {
		height: 120px;
		width: 150px;
	table
		border-color: #600;
	th,td
		border-color: #600;
		padding: 4px;
		width:200px;
	</style>
</head>
<body>
<h1>Search</h1>
	<fieldset>
	</fieldset>
</form>
	<table>
	<tr>
	<th>Acc No</th>
	<th>E-Mail</th>
	<th>PDF</th>
	</tr>
	<?php
		// Get results
			// Save the list of found account IDs
			array_push($arrFoundIDs, $temp['AccID']);
		<tr>
		</tr>
	<?php
	</table>
	<h1>Unfound IDs</h1>
	<table>
	<tr>
	<th>Acc No</th>
	</tr>
	<?php
		// Show unfound IDs
		foreach ($arrFilteredIDs as $ID) {
			if (!in_array($ID, $arrFoundIDs)) {
				<tr>
					<td><?php echo $ID; ?></td>
				</tr>
			<?php
<?php } ?>
</body>
</html>
Bits added:
Code:
/* LINE 30 */
/* LINE 101 */
/* LINE 117 */
<table>
<tr>
<th>Acc No</th>
</tr>
<?php
	// Show unfound IDs
			<tr>
			</tr>
		<?php
Thanks a lot man, just added this in. Works great :)
I'm just touching up a few things with this PDF export and should be good to go!
Nice, glad it works :).
I didn't even attempt to understand your PDF code, the url looked quite complex :o.
