after-market vrm heatsinks
4 Apr 2020
I'm curious how effective this option is for entry boards like the b450m pro m2 max without heatsinks.
I'm thinking down the road when I decide the stock cooler needs replacing and begin wishing I shelled out for a better board.
The tall, thin finned, copper, alphacool ones look like they might work well. If I get extra I can put them on mosfets everywhere.
Cheers
* after some investigating the Fosa stepper motor driver heatsinks cooling fins for the TMC 2100 3d printer look almost made to order
It can't hurt can it, I would start by look at what sort of temperatures you're getting and go from there. If you do install some then make sure the height does not interfere with any surrounding components such as the CPU cooler.
Thanks for the reassurance.
I'm suspect I'll be ok.
Cheers
Anything resembling heatsink is definitely better than no heatsink at all.
Though even with heatsinks that anemic COPD crippled hamster isn't good for above 65W TDP CPUs.
Just remember to put heatsink on MOSFETs instead of chokes.
