Afterburner 80% fan lock
6 May 2009
I have Afterburner 3.0.0 Beta 19 and an EVGA GTX670.
The fan speed always tops out at 80% in custom fan curve and trying to set manual fan speed (you set 100 and it goes back to 80)
Is there a way to unlock it so it can use its full potential?
It was the same in previous versions of Afterburner
Not if read their site.
You can use a modded non EVGA Bios etc so long as its back to stock Bios when you RMA it.
Some models have dual Bios so you can play with modded bios and all is allowed.
The fact you can simply change 1 setting in your bios and reflash with same bios IMO is well within the rules.
Capture Bios with GPU-Z, change the max fan setting with KGB and flash it with the Bios.
I made my 680 4GB FTW 30-100%.
