- 12 Dec 2006
i recently bought a new helmet to replace my arai condor (now relise the mistake)....
note to people dont buy an arai then exspect to be able to use another make.
anyway i have bought an AGV S4 SV gold and black helmet. (needle and hay stack) there was only one in the country in my size.
anyway now after a 5 mintues test ride in the $%^& thing i cant go above 40mph due to the unbearable wind noise, its like having two ref whistles constantly blown into your ears.
if tried many times to alter the visor fitting but i just cant fix the problem.
the visor dose not seal well against the rubber and is letting air in some where around the visor mechs on the sides but i just cant get the visor to pull tight.
obviously as normal i cant take it back as ive used it.
has anyone here had problems with agv helmets? any recommendations?
