I found that adding an active backplate to my 3080 while not financially sensible (I did manage to luckily pick mine up unused for £50 off Fleabay), it did manage to help a few degrees on the memory junction/hot spot. Likely just heat transfer through the back of the card onto the thermal pads.
I actually got my main GPU waterblock from OCUK b-stock and while the first one they sent me was a straight return, thankfully the second b-stock attempt while without a sleeve cover, look unused. So I got front and back all in for like £140. Just 3080 FTW3 EKWB Vector version 1, but I'm really happy with it. In the year or two to come I guess if I ever marginally upgrade to a 3090 (More VRAM/bit better performance) this block will be good for it as well.
Going to skip first 4xxx iterations and be patient on a GPU upgrade for years to come. My next move will be AM5 at some point.
Ignore the power draw above at 213w, sadly I have one of the 3080 FTW3 cards from EVGA that flat out refuses to draw over 400w, even when using a 450w BIOS. EVGA are plagued with original 3080/3090 power draw issues for anyone trying to max out the cards.
So after months of posting about it on the official EVGA forums and EVGA themselves ignoring the issue, I actually found out if you flash a MSI BIOS (my card is an LHR variant) from this card
https://www.techpowerup.com/gpu-specs/msi-rtx-3080-suprim-x-lhr.b9129 onto your 3080 FTW3, while it breaks power reporting, it actually allows the card to draw up to 500w. No Asus/Gigabtye 3080 BIOS works with the EVGA 3080 FTW3, I mean, they flash and run, but they actually stop one of three pins working, so you end up with LESS power draw.
While I've not measured this MSI BIOS with clamps, I have done it through my HX1000i iCUE digital power readings, and just crudely subtracting CPU power draw and leaving a margin for all other components. Not to mention running something like Metro Exodus EE, which easily power limits on a 400w limit if you crank everything up to max and want to try and run core at like 2100mhz. Doesn't power limit on the MSI BIOS until you get up to like 2160mhz.
When I posted this topic I was playing FF7R with the Flawless widescreen plugin, so running in 3400x1440 and with the internal resolution set to 130%
Given how poorly optimised this port is, not only can it use over 7GB of VRAM quite often, it easily draws 450~500w on those settings above. Hence my GPU at 45 degrees on a warm night.
