- 5 Jul 2007
Hi folks
About to install a solid state drive on my system with my old 2TB data drive already in existence...
I have read that AHCI needs to be enabled to gain the maximum performance possible with the solid state boot drive (under Win7-64). My dilemma is that I have seen the problems caused by enabling AHCI after installing Windows AND my bios only allows AHCI to be enabled for ALL SATA2 ports or not at all (current IDE mode instead).
How will AHCI effect my old data drive ?, is it that only boot/operating systems are effected, data drives don't mind the mode change at all ???
Thanks
Thanks
