- 16 May 2007
I have a Gigabyte Z68XP-UD3 motherboard with i7-2600K which I have been running with a mechanical HDD and smallish SSD which I use as a cache drive in rst. When setting things up originally I set the bios to RAID-XHD as recommended and things have worked ok.
I have however recently purchased a Samsung 850 EVO which I intend to clean install W10 to rather than clone and upgrade from W7.
I do not foresee ever setting up a raid array and with the ssd I certainly won't need a cache drive.
My question is should I set the SSD up as AHCI rather than XHD (which from what I can see includes AHCI) or are there any benefits to continuing the use of XHD even though it is in a single drive system.
Thanks
Thanks
