AIO cooler 360mm for intel i910900k recommendations
25 Nov 2014
Boston lincs
Hi all
I’m just staring my new build ASU’s maximus hero z490 ...intel i910900k in a storm trooper case
Any recommendations for Aio liquid cooler 360mm size
I’ve read so much good reviews and bad reviews I’m stuck
Any help much appreciated
Thank
Tink
27 Jun 2005
Reading
I have the arctic freezer II 360mm, very good cooler. Easy to install, quiet and performs well.
30 Mar 2007
Arctic is the best at the moment in terms of value to performance. Also only needing 1 cable to power everything makes life easier.
Just make sure you are aware the radiator is thicker than normal AIO rads at 38mm (not including fans), so ensure you have clearance if wanting to mount in the top of your case.
OP
25 Nov 2014
Boston lincs
Thanks Coys i have a CM stormtrooper cas they are quite large im gonna check it now to see
