AIO Cooler.
Thanks, I appreciate it :)
Unfortunately I can't find much info on the Zalman R1 so I am unable to say exactly what will fit in the top. You could look at the Nepton 120XL, as it sits on the rear fan space, it will fit. Whereas I am not too sure about the top section and clearance issues. sorry I can't be more help than that. As suggested if you measure the distance from the top of the case/the bottom of the default installed fan, we should be able to work it out from there.
Okay, I'll pull it out and have a proper look, after reading the above post properly it said 52mm not 57 which i thought it said. I probably have a chance!
I couldn't find much on the case either, ah well. I'll figure something out
But thanks for looking into it for me.
No problem. Any questions, just drop me a PM.
Right, it would fit if I had a different motherboard, mine has a fin behind the cpu means that it's about 4mm in the way.
I went to my local ** ***** and got a H55 120mm. It fits in the right fan slot but can't slide over so will not fit a 240 :(
Now I've got this corsair h55, I kinda want to keep it, I only paid £20 for it as I got a voucher for Christmas and don't need anything else from there haha. Fits nicely on my rear fan
Thanks for your help guys, any other situation it would fit, me being fussy and wanted a cool looking mobo means I cant :(
Get a new case :p
Obviously only it it's an option, but it's something that would probably see you through the next 6 or so years
Yeah, I will be when I get my full water cooled system in a few months time.
If I get one now I'll just get one I don't really want and be bored of it by the time I do my WC.
6 years!? I've never owned anything for that long. 1 year max for a case! Got to switch things up!
