So you can have an anime waifu on display, duh!I must be out of the loop, but why do you need a 3.5" LCD on your cpu cooler?
Calked Asus DIY Facebook groupWhere might one find these groups? Reddit?
I was under the impression that these AIO coolers only lasted a few years. Are they generally that longlasting? I've yet to make the jump from chonky air coolers. If I was going to, no way is this Asus thing on the list!Corsair H50 from 2009 still trundling away. Outlived the original i5 750 CPU which I replaced with a i5 760 for £5 from CeX this year.
What In the blue hell is this!! Who buys these things??![]()
ASUS ROG Ryujin III 360 ARGB Performance AIO CPU Liquid Cooler with OLED Display - 360mm
Order ASUS ROG Ryujin III 360 ARGB Performance AIO CPU Liquid Cooler with OLED Display - 360mm now online and benefit from fast delivery.www.overclockers.co.uk
£450 for a cooler? This is just getting stupid now.![]()
Pump failure is quite commonThe better brands are offering 6 year warranties.
Worst case failures like a liquid leak get the most attention but I don't know what a normal failure is for an AIO.
I reckon it's a slow degradation in performance between the pump bearings slowly wearing and the fluid incredibly slowly escaping through the walls of the tubing. But both of those are engineering problems that can be worked on, like being less cheap with materials. I have no idea of the timescale this would normally take to be noticeable.
Apart from that, what else can go wrong in normal use. The tubing isn't getting beat up, everyone uses black tubing to avoid light issues and the liquid may well be glycol and/instead of, water.
Well the fans could and probably will croak but the main part of the AIO is a sealed loop with one moving part. At the prices they've reached surely they've managed to make that single moving part last forever now.
I had a pump failure on my Arctic Liquid freezer II after 3 years. I bought it in 2019 and it failed this year. Arctic replaced it with a brand new AIO under warranty.Pump failure is quite common
Nice result, pump failure is the reason i always have the rad in the roof, i dont know if it would help but it makes me feel better.I had a pump failure on my Arctic Liquid freezer II after 3 years. I bought it in 2019 and it failed this year. Arctic replaced it with a brand new AIO under warranty.
