Hi, I'm looking at purchasing my first 240 AIO (Cooler Master Seidon) but have a few questions on how I would power it.
As far as I can tell, there will be 3 connections from this; the pump and 2 fans. My board (ASRock AB350M) only has 1 x CPU Fan Connector and 2 x Chassis Fan Connectors and the case I will be getting has 2 fans included already.
Would it be better to remove the front Fan, mount the AIO at the front as an intake and use a fan splitter to connect the 2 fans from this to the CPU FAN connector and use the other chassis connector for a fan at the back for exhaust? The pump would also connect to a chassis fan connector.
In my current case, it has fans that run off the power supply so I can make use of that for extra exhaust fans at the top or for any other fan.
Is this the best way to run it?
