this guys knows what he's talking about LMAO. i still have a zalman lq315 from 2014 that is still working in my mates 2600k system for daily use. one of the best 120mm aio's i have ever purchased.you will know when the AIO is dead, it will take the rest of the components with it.
he's already looking to build a new pc anyway hence why he is still using that old aio. no need to buy something else when he already has the funds for his new build. just surprised that thing still works and keeps his 4.2ghz 2600k at 65c under loadWould your mate not feel more comfortable in thinking about replacing it soon...? Just thinking about some aspects of degradation, perhaps in the seals as well, rather than the mechanical functionality. I don't know how comfortable I would be with an AIO that has been well used for so long which might increase its chances of failure. If that failure includes a leak it could be pretty bad.
So many ifs and perhaps I know, probably not helped as I am using my first AIO, 420mm Arctic Cooling, and have little practical experience of them over the long term.
Yes.I think I may have a problem with my AIO.
I bought an 8pack system about 3 years ago and I've noticed recently that my aio seems to make a loud rattling sound at times when I start up. I end up having to restart a couple of times to make it go away. The temperatures seem pretty high as well, right now I'm browsing while watching netflix and the temp is 50c whilst gaming in Cyberpunk makes it go up to the high 90s. The cpu itself is overclocked to 5Ghz.
Should this be a sign to replace the CPU cooler?
I thought so tooCan anyone recommend a good AIO? My case can fit an AIO with 240mm fans.
Besides not having brand and fashion hype overprices Arctic is far better with 50% thicker radiator for proper surface area.Is there a major difference between the 2?
Smaller slim radiator waterpipe coolers actually struggle against top heatpipe coolers in continuous cooling per noise.
They simply don't have that much surface area for dissipating heat into air.
The Arctic AIO I linked is super thick, well respected, and has a six years warranty. One cable only to fit on the non bling type. Not sure why much else would be considered over that based on its cost / performance and quality considerations.
Less fiddly, fans are also pre-fitted to the rad, for you to think about.
You mean a 420 or a 360 for the front, you mentioned 320....? Top mount seems the preferred choice for me.
The unconventional design of Carbide Series Air 540 utilizes dual chambers to deliver cooler air to your CPU, graphics cards, motherboard, and memory without your drives or power supply getting in the way. The included custom Air Series AF140L intake and exhaust fans provide great airflow performance at lower noise levels than typical case fans. And, you can mount up to six 120mm or five 140mm fans, with 280mm top radiator support and room for a 360mm radiator on the front panel.
Like all Corsair cases, Carbide Series Air 540 is designed for fast, neat, and satisfying builds. The tinted, oversized flush-mount side window lets you show off your work.
