Hey,
I have recently purchased a DarkRock Pro 4 and while it does the job of being silent and having good temps... it does make things awkward in regards to removing the graphics card and well.. if i am honest just doesn't look good.
I can't help but consider a AIO due to the looks. I know from a practical stand point it makes no sense due to it costing more, possiblity of pump failure and so forth but there is something about seeing the sleek design of the VRMS and Ram that make it very appealing.
I guess ultimately there are two things i wish to ask. Is there any aircooler that has the ability to solve the above problems and the other being that my Phantek P600s. While using stock config and fans. The cooling feels subpar from the fans. I can set the fans to 70 percent and still feels lackluster in terms of airflow with the panels off on the case.
I have looked up SW3 for both apperance and practical for the purposes of replacing the 3 stock case fans. I did have a look at the Eloops but read reports of them conflicting unless having 5mm of space? (The 28mm version in black)
