I'm re-using a box I built as a home server as a gaming PC and need to quieten things down. The CPU is an AMD FX-8320 with a stock cooler and the GFX card is a Radeon R9 285, both of which are power hungry space heaters.
I'm not really looking to OC just want to reduce the noise levels. My case (another vendor's own brand "gaming case") has room for a 140mm fan on the back and 2x140mm fans on the side.
My question is would a single loop custom setup with a 280mm rad on the side and CPU and GFX blocks be better than the simpler and cheaper option of a couple of AIO coolers like the NXZT X41, one for CPU and one for GFX?
