AIO orientation when front mounted?
1 May 2013
M28
Does it matter if the radiator tubing when mounted on the front of the case are the top or does it have to be at the bottom, gravity, air ?
I take it the space where the tubing goes is some kind of reservoir?
Nepton 140XL
Not sure if it does mater. When I had a H60 I orientated mine on aesthetics. looking at photos on the net, I would say it does seem to be more about getting a 'look' that you like
