Hey all, running the rig in my sig and just wondered what the general consensus was on the placement of an AIO radiator?
Currently have mine on the front with 4 x 140mm push pull configuration. Other than 1 other 120mm intake case fan in the bottom i have no other intake and am concerned that once the rad heats up a bit its then blowing warm air into my case.
If i place the rad in the top i will then be blowing warm air from the case over the rad...
Not entirely sure which option is better to be honest and would appreciate a little professional input.
Thanks.
Thanks.
