AIO setup + fans Help
21 Aug 2017
Hi there.
I just brought a corsair 750D case and a thermaltake 3.0 360 AIO . now without actually realising and also forgetting to look things up (over excitement ordering new parts) im now baffled at how to set these 2 up inside my case.
NOw i have looked everywhere for an answer but there so many different ones and after hours of reading, im still not quite sure what to do.
I believe myself that i should have the 360 RAD at top of case an an exhaust with 2 front fans and 1/2 at the bottom of the case.
Is this the right way to go or is there a better way?
Im also thinking of the positive/negative air flow too, and this is the first time owning a 360 RAD with 3 fans, because i am use to having a H80i corsair in my case with is only one fan on a push pull config and 2 fans at the front so its kinda baffled me a little how to setup this new AIO and case.
Any suggestions would be much appreciated for what is the best way.
My parts
https://www.overclockers.co.uk/ther...on-all-in-one-cpu-cooler-360mm-hs-04g-tt.html
https://www.overclockers.co.uk/cors...tower-case-black-cc-9011035-ww-ca-157-cs.html
P.s no drives bays are needed either for room space inside case.
Plenty of options in that case... Start simple and change / add fans if you're not happy with noise or thermals.
What graphics card do you have? The CPU will be coolest with its fans set to intake, but the graphics card may see higher temps as a result.
In a big case like that it's less of an issue, you may find an extra intake or two at the front are enough to let war air eject through grills etc.
Experiment!
