Hi Everyone,
I'm currently running a CoolerMaster 240mm AIO, ML240R on a stock Ryzen 3600.
I'm planning a switch from ATX to an ITX setup imminently, and was wondering if replacing the entire AIO or just the fans would be worth it.
I'm looking at the Corsair H115i Pro XT as the Arctic Liquid Freezer ii 280 doesn't look like it will fit in the case (CM NR200).
I want good thermals obviously, but prioritise noise levels as this unit will sit on my desk. Primary use case is gaming, probably do some minor overclocking of the cpu.
Any recommendations?
Thanks!
Thanks!
