- 29 Jul 2017
I recently changed my case from my Aerocool DS Cube as it was getting rather hot even with all fans running etc.
I got my hands on an air 240 which is actually smaller but a much better layout. I Highly reccomend this case to anybody looking for a great Matx Case.
My only thought of negativity on this case is that to run the 8 pin mobo atx cable behind the tray you need to remove the 3.5 Hdd Cages and then pin the cable into place before putting it back and its a tight fit. Overall it really is a great case.
Anyway Im looking for ideal on what to do with my DS Cube case. I already have a computer for MRS which she loves and a HTPC is a PI3. So stuck for ideas.
Any suggestions?
TIA
Any suggestions?
TIA
probably the one weakness of the case.
