Air blower duster for pc
14 Oct 2007
wubalubadubdub
I have been looking for some kind of electric air duster for the PC but all of the small 'computer' ones are priced £45 upwards, however I have found many leaf blowers priced as little as £16+, my question is would one of these be OK to use on PC or would it be overkill and maybe damage the parts? and would it be able to get the harder to reach dust out or should I try and find something with a smaller nozzle option?
Same as above I have the compucleaner one and trust me its more than powerful enough lol it does come with a few different nozzles you can attach as well.
The one I was looking at is £45.
*** REMOVED ***
Never considered a leaf blower. Off to search.
I've had this one for the last 3 years and wouldn't go back to compressed air. The only downside to this is there is only one speed option which some may not be too bothered about.
Wouldn't a small vacuum cleaner be better as in it will suck and contain the dust rather than blowing it all over the place?
Or is this just for really clogged up things like heatsinks.
I just do it outside once a month on a dry day with my xpert compucleaner, it's always surprising how much dust there is after only 30 days and with decent dust filters on the case
And I wouldn't link ***elsewhere*** as OCUK have started selling the same ones recently, they're cheaper than ***elsewhere***
My basket at Overclockers UK:
Total: £47.34 (includes shipping: £7.39)
STATIC!
I have always used vacuums in the past without problem, but the whole internet seems to think that vacuums can cause static damage and maybe I am getting more paranoid of this with age and with hardware prices always going up the risk seems higher now
Datavac is probably the best one: *** REMOVED ***
They are more expensive, but well built and pretty powerful for their size. They can blow and suck at the same time if you stick a nozzle on both ends, which is pretty good for collecting dust.
STATIC!
Internet is full of paranoia on pretty much everything, its a wonder anyone does anything :p
i'd agree w/ this post - what's the benefits of simply blowing dust all over the place as opposed to sucking it up and away?
I can't believe the blowing power of a compuclean is as good as the vacuum from the hoover with a restriction nozzle (usually with a small paint brush),
it would just be more manouverable ... a small compressor might work too, and be useful for other purposes (drying off bicycle parts after cleaning ;))
