I can't believe the blowing power of a compuclean is as good as the vacuum from the hoover with a restriction nozzle (usually with a small paint brush),
it would just be more manouverable ... a small compressor might work too, and be useful for other purposes (drying off bicycle parts after cleaning)
Wouldn't one of those electric air pumps you can use to inflate kids swimming pools and air beds do the same thing?
Been using an air bed pump for years, does a good job and have had no problems
A lot cheaper than £45
Adli/Lidl air compressor + Airline
Then more reason to buy powertools![]()
The cans are good but are a bit wasteful and the cost add up over time. I have been tempted to buy one of the vac ones mentioned as it'll pay for itself over time compared to the cans. Using a vaccum isn't wise as you could cause static onto the components. It is the only way though if you can't take it outdoors.Give it a try whilst videoing it and post it here.if you're just going to blow the stuff around, why not just blow down a tube then, instead of spending 50 quid or such?
Who keeps components long enough for them to accumulate dust.![]()
Anyone know why the CompuCleaner Expert i bought from a competitor came with these attachments.....
The cheaper £39 one on ocuk has the same attachments https://www.overclockers.co.uk/it-d...ginal-ii-electronic-air-duster-kb-000-id.htmlAnyone know why the CompuCleaner Expert i bought from a competitor came with these attachments.....
.....instead of these far more useful looking ones from OcUk?
Thanks
Oops I just noticed that you did buy the Xpert versionYou do realise the side of the case is off so the dust goes outside?i would if i advocated blowing dust around, but as i posted earlier, i don't.
looked an Amazon and less than £8
