- 6 Jun 2011
Hi guys,
I am in the market for a cheap yet effective air compressor. The main issue is I only really need it for one thing but I will either sell it when used or keep and have it for other things.
The main use is to do a job on my car where I need to spray underbody seal to deal with a leak. I will be doing this with something known as a Schutz gun, which you can see in the picture below:
According to the specification it has a working pressure of 6Bar/90Psi.
My budget for the compressor is no more than £100 but preferably a lot less if possible? As an example here is one I have found which seems like it would be suitable it's just a bit expensive.
Stanley 8216035SCR011 24Ltr Compressor with 5 Piece Accessory Kit 240Vr
Hopefully there are some air compressor experts around
Thanks!!
Thanks!!
