Air con multi-splits: which of 2 approaches is better?
13 Jun 2009
I'm planning to get air con in my new house. Use cases are:
Cold snaps: Top-up heating in conservatory during day and kids' bedrooms (2 & 3) at night
Summer: Cooling in conservatory on weekends/holidays, cooling in office (bedroom 4) on weekdays
Heatwaves: Cooling in lounge & conservatory on weekends/holidays, cooling in office (bedroom 4) on weekdays, cooling bedrooms 1-3 at night
The plan of the house is here. We're going to extend the house to add 2 extra bedrooms above the garage in 2-3 years' time. We also may open up the conservatory, dining room, and kitchen into one large area.
I've had 2 quotes from Daikin installers that have different approaches and would like to hear your thoughts about which is better.
Installer 1
- 5kW single split (FVXM50A) for conservatory & dining.
- 4kW outdoor unit (2MXM40A) connected to 2x 2kW indoor units for kids' bedrooms.
- 5.2 kW outdoor unit (3MXM52A) connected to 2x 2kW indoor units for lounge & master bedroom connected to 1x 1.5kW indoor unit for office with pump (pipework through loft).
- An additional 2-way multi-split can be installed in future once extension is done.
- All 3 systems to be run off different ring mains.
Installer 2
- 5.2kW outdoor unit (3MXM52A) connected to 1x 2.5kW indoor unit for conservatory + 2x 1.5kW indoor units for kids' bedrooms.
- 9kW outdoor unit (5MXM90A) connected to 2x 2.5kW indoor units for lounge & master bedroom + 1x 1.5kW indoor unit for office with pump (pipework through loft).
- 2 further indoor units can be connected to the 5MXM90A once extension is done.
- 2 new dedicated circuits for power from garage (via loft).
Installer 2's approach of oversizing the outdoor unit so we can connect more indoor units later is an interesting one but I am not sure how this will affect efficiency, particularly if we only have, say, the office unit on during the day.
Installer 1 thinks 3 outdoor units will work better to reduce pipework and also thinks we need a much bigger unit for the conservatory due to the large number of windows and sky lights, plus it's south facing. If we ever open up downstairs this will help also. But again, for now will the efficiency be poor if the unit is 5kW?
Also, everything I've read suggests single splits are cheaper than multis but that doesn't seem to be true where I live (UK). Installer 3 recommended 6 single splits and wanted to charge 30+% more than the two installers mentioned above.
Based on this, which approach (if any) would work best in your opinion?
If you have an inverter heat pump it only runs to the capacity of the load, therefore if only one indoor unit is running the efficiency doesn't take a hit.
Not a chance I'd want the outside of my house plastered with loads of heat pumps, it would look like a total mess and is done to save the installer time.
I'd go for the largest capacity multi-split system possible which would work on single phase.
Can you explain why outdoor units have minimum power ratings if they only run at the load demanded? E.g. it might say "4.0 to 9.0kW" (can't remember exact numbers). I assumed that means it will always provide 4 kW of cooling even if only 2 kW is demanded (with 2 kW wasted).
The way the house is laid out, none of the outdoor units would be visible from anywhere people would be, with either approach.
No that would be crazy, an invertor heat pump is not just "on or off", it varies its compressor speed to meet the cooling demand, if you think of it like a car engine you are not a million miles off.
The compressor has a minimum speed it can operate and thus minimum amount of cooling power it can produce, if the room is not calling for cooling at the minimum power then the compressor turns off therefore a moot point.
A non-invertor heat pump works a little more like you described i.e. fixed speed, except when the cooling target is met the compressor turns off.
This is very confusing because even recent articles and posts mention how multisplits are much less efficient when not all the indoor units are being used. Are they really all talking about non-inverter units? I thought those weren't even sold any more.
If I understand correctly, longer pipe runs also reduce efficiency, which also makes me weary of over-sizing the outdoor units to later connect 2 more. There'd have to be pipework all the way from one side of the house to the other.
Some expensive systems proposed. I have a similar upstairs layout and went for a ducted system which although I lost the flexibility of individual temp control meant I didn't lose wall space and saved quite a chunk of money. Then a separate wall unit in the lounge. I have a 7.2kw outdoor unit from memory with a 5kw in the loft and 2.5kw in the lounge. The outdoor unit has the capacity to add another indoor wall unit or 2 according to my installer which I'm planning on doing next year in the conservatory.
Your outdoor unit will just do what's needed to exchange the heat with the indoor units demand so will ramp up and down. No idea what you've been reading...
Yes I understand that, but how low can this realistically go without affecting efficiency? Say one indoor unit only requires ~1kW to sustain temperature from a 9kW rated outdoor unit. Would that be much less efficient than an indoor unit requiring ~1kW from a 3kW outdoor unit? Seems to be conflicting opinions on this and I can't find a reliable source, e.g. a datasheet that specifically mentions this scenario.
I'm pretty sure it'd be nigh on negligible and the savings you'd make from buying one outdoor unit and the reduced pipework, electric cable runs etc would pay for that difference many hundreds of times over, and in reality you'd be putting enough demand on the unit anyway for your use cases.
Installer 1
Installer 2
We have a couple of units installed, if you are anywhere around Northamptonshire give these guys a call. I know the main chap Rob very well, they supply and fit units for homes and larges businesses. He’s been in the business years, I also noticed they mentioned fitting one in Warwickshire so they do travel https://www.facebook.com/northampton.air.conditioning.and.refrigeration
Also to add… We had an apartment in Cyprus with aircon in all rooms, we had a few nightmares and heard other horror stories with with some brands but here in the UK we were split between Daikin and Mitsubishi and after a bit more research we opted for Mitsubishi
Two years on and we‘re pleased with the choice, they are excellent at heating a room too and use about 600watts to produce the heat
You’re right with what you’re saying there is a slight drop in efficiency if you’re running a massive unit to do little to no work but it’ll quickly reject the heat and cut off, so it won’t make much odds in the grand scheme of things.
I‘d go the multi route myself, I’ve got a 6 way multi with 3 indoor ducted units. 1 ecodan and 1 split.
I’m going to put one in the conservatory in the spring as well and it’s getting a bit of an eye sore. :D
