- 18 May 2010
Hi,
I need an air cooler thats max height 153mm which is a bit of a tricky one as not many available at first look, as I've not been in a situation with limited height before I thought I would check for any go to coolers for this kind of height restriction
I'd prefer not to have a downdraft cooler really as it would cover most of the board and I don't really like that
No budget for this as I need the best I can get
I've been looking at the NH-U9S but can't be doing with the brown fan so would end up quite expensive for not so impressive performance when swapping the fans out
Cryorig H7 would fit but I read you have to fit them from the rear and their fans are often commented on being loud
Any others out that that I might have missed?
Thanks
Thanks
