Air cooler for AMD 1090T plz?
24 Nov 2008
Hey guys
I am using a stock cooler with my 1090T at the moment but i would like to upgrade to a better Air cooler, Can anyone suggest a nice cooler that will not break the bank up to £30 would be great. Nothing too loud either would be great.
Once that is done i will then have a go at a slight overclock using the Asus crosshair software.
My spec
AMD Phenom II X6 Black Edition 1090T
Asus CROSSHAIR IV FORMULA 890FX
Thermaltake toughpower 650W
Asus Xonar D2
8 GB Corsair CMX8 XMS3 DDR3 9-9-9-24
Antec 900 case with stock fans on Medium speed setting
OCZ 60GB Vertex 2E SSD 2.5" SATA-II
WD SATA-III Caviar Black 7200rpm 64MB Cache 1Tb Raid 0
Thankyou
Leigh
I was going to post a thread like this but mine as I will piggy back yours. I have a few questions based around my 1090T. My specs are:
AMD 1090T BE @3.7ghz
Arctic Cooling Freezer Extreme
Asrock M3A770DE Mobo
4GB OCZ Platinum 1333 ddr3
OCZ StealStream 500w .
I am looking for a good cooler as well. I do also have a few OC questions. I can not seem to get my CPU stable over the 3.7GHZ mark. I am wondering if this could be down to my Mobo being quite cheap? Or, what else may be causing this? My current high on Prime95 is 65C which I know is a bit higher than most like but I never plan on using 100% CPU . I have tryed COD MW2 for over 2 hours and only reach 39c according to HWMonitor. Idle is about 32c. Does this sound about right?
Sorry for hoping on your thread mate just figured it may be a bit easier and work out a bit better for both of us in the long run .
Cheers for the reply's no probbs with using this post at all
What Case are you using? maybee an airflow problem?
Anyways
I have been looking all day at coolers and i am thinking of spending a bit more cash i quite like the look of this and it has had pretty good reviews but it is a monster of a cooler in size 98(W) 165(H) 139(L)
http://www.overclockers.co.uk/produ...catid=57&sortby=priceDesc&subid=1395&mfrid=54
Or this with a extra fan fitted, Also good reviews
http://www.overclockers.co.uk/showproduct.php?prodid=HS-029-CM
Not so much of a overkill maybee?
what you recon?
Leigh
im very happy with my coolermarster v8 in a antec 900, dont even bother with the front fans any more. just the top fan on low, rear fan and cpu fans runing 900-1000rpm bios controled. nice and quiet
temps 33 idle and 42 load.
Hey guys im still looking
The problem is though the more i look the more i get confused, anyway lots of options here.
Ok I should not skimp on a cpu cooler so my budget is now more if required.
Any thoughs on a silver Arrow?? not a bad price at the mo either?
http://www.overclockers.co.uk/showproduct.php?prodid=HS-078-TR
I know this is a big cooler, I have not found much info about this fitting into a antec 900 case as i want to fit the side panel on, Also i would have to remove the Motherboard to fit the brackets and also and i am not sure about my memory sticks conflicting with the 140mm fans? as all my memory slots are filled.
On the other hand cooler master V8 or Cooler Master Hyper 212 Plus and buy 2 nice fans for it?
I think i might be over doing it by getting such a huge cooler, Im not going to seriously overclock the cpu i was thinking around 3.6-8 Ghz
Help please before i go mad.
Cheers
Leigh
just fitted a coolermaster hyper212, £20 from ocuk, very quiet and load temps 41*c(prime 95 for 30 mins) in an antec 300 case
