Air Flow Mini Concept
Recently having obtained a Silverstone PS07 Black for the grand sum of 40 quid (to good a price to pass up) and with a view to possibly watercooling once again at a later date...
I present to you -
Air flo Mini Concept
The build criteria remains the same namely
Where does the PS07 differ from the TJ08???
Outwardly the PS07 presents a smooth front with the front panel connectivity vertically mounted on the left side of the facia whereas the the TJ08 has it mounted just above the mesh
They both share the same chassis and internal layout with but one all important difference, the TJ08 uses a single 180mm Air Penetrator front mounted intake whereas the PS07 uses 2 x 120mm front intake fans
So why change?
Simple, the PS07 allows me to front mount a 240 radiator at a later date with minimal fuss (versatility and future upgrade potential)
Thank you for looking
I present to you -
- It have 2 x SATA3 6.0 Gb/s connectors
- A PCI Express 3.0 x16 slot
- It should be Z77 ITX
- It should both be quiet and energy efficient
- it should be able to overclock like the Devils own
- It should outwardly and inwardly appear modest, minimalistic and purposely understated
So why change?
