- 21 Dec 2019
- Planet Thanet
Just to add
There is a middle ground between AIO
And custom loop
If you can get hold of one in the uk
Swiftech AIO which is quality components with the ability to be expanded
No aluminium radiator or asetek pump
And not sealed like most AIO it has standard compression fittings and standard 3/8 I'd 5/8 od tubing
Or 10mm/16mm if you think in metric![Smile :) :)](/styles/default/xenforo/vbSmilies/Normal/smile.gif)
And custom loop
