AIR480
16 Oct 2016
Hi all,I'm ADmodz.
This is my latest project,sponsored by Corsair,alphacool,scan computers,msi,Mayhems.
I've taken 2 corsair Carbide Air 240 cases and made them into 1.
System specs:-
X99 platform
Motherboard:- Asus ROG Strix gaming x99
CPU :- Intel i7-6800k
GPU:- MSI GTX 1080TI SLI FE
Memory :- 32 gig corsair Dominator Platinum 3000mhz
M.2 :- corsair Force MP500 480 gig
SSD:- 2 x 480 gig corsair Nuetron XTI
FANS :- 6 x corsair HD120
PSU:- corsair RM 1000i
Watercooling:-
CPU BLOCK:- EK-FB x99 monoblock
Gpu blocks :-EK GTX1080 TI
RADS:- 2 x EK Coolstream XE 240
PUMPS :- 2 x EK-XTOP Revo D5 PWM - Plexi
RES:- 2 x EK-RES X3 250
Hardline tubing:- Alphacool 13/10 acrylic
FITTINGS:- Alphacool Eisapfen 13mm chrome
Coolant:- Mayhems pastel orange and Mayhems XT1 clear with orange dye.
Well I've got the cases stripped down and time to start chopping them up.
I'll start with the front and side windows,and the bottom side vents.
That's it now for a couple of days,got to get a clients build done.catch you all soon.
UPDATE2
Well today got interesting,time to see how steady my hands are when doing fine cuts.
A few little marks,but nothing a sand and a blob of body filler will sort out.
That's the 2 front windows cut and the side panel windows.
Little bit of tidying up,but starting to look like the vision in my head now.
Enjoy......
Just bits of sanding to do now and I can weld the 2 case halves together.
interesting concept for sure, i'll hazard a guess and say all the rads are going in the basement of that? hoping to see more soon looks very promising!
Thank you.
Yes 2 EK 240 rads are going in the basement,a new aluminium basement floor is being made,with the fan holes and a couple of air vents.
UPDATE 3
AIR480 case feet have finally arrived.
Very happy with the finish,I will be running a gloss orange stripe in each groove.
Happy chappy.
The new case floor is away at the laser cutters as well.
Well managed to get the case panels done ready for hydro graphics.
Holes filled that are not needed.
And a good sand all over.
The new aluminium floor is still at the laser guru's, but looking fantastic.
Would like to say a massive thank you to Mayhems Solutions for supporting the fluids for AIR480.
Pictures of fluids coming soon.
UPDATE 5
Well the fluids turned up today.
Big thanks to Mayhems Solutions for supporting the AIR480 project.
I think I've hit the colour of one loop on the head.just what I imagined.
never too keen on the pastel range, but that orange does look epic. Of course, if you can get his orangeness davido_labido to give you a thumbs up you know you're onto a winner.
In fact, I'm surprised he didn't show up the second "orange" was uttered :p
