Hi all, I am getting the Ryzen 9 7950x and I want air cooler instead of water cooler.
I am after some recommendations. Which one would you recommend? I want the best available within a reasonable budget. I would say budget can vary but was looking in the range of £50 - £100.
I was looking at the Noctua NH-D15 but there are som many variations. Don't know which one is the best. Maybe there is one that's similar and costs less.
Looking at the option on overclockers website:
I wonder if I should go to the be quiet one and save £30.
Thank you.
Noctua NH-D15S Chromax Black CPU cooler - 140mm £110
be quiet! Dark Rock Pro 4 CPU Cooler - £80
Thank you.
