Airfix 1/48 Hawker Sea Fury FB.11
5 Feb 2006
The Hawker Sea Fury is a British fighter aircraft designed and manufactured by Hawker Aircraft. It was the last propeller-driven fighter to serve with the Royal Navy, and one of the fastest production single reciprocating engine aircraft ever built. Developed during the Second World War, the Sea Fury entered service two years after the war ended. It proved to be a popular aircraft with a number of overseas militaries, and was used during the Korean War in the early 1950s, as well as against the 1961 Bay of Pigs Invasion of Cuba.
The Sea Fury's development was formally initiated in 1943 in response to a wartime requirement of the RAF, thus the aircraft was initially named Fury. As the Second World War drew to a close, the RAF cancelled their order for the aircraft; however, the Royal Navy saw the type as a suitable carrier aircraft to replace a range of increasingly obsolete or poorly suited aircraft being operated by the Fleet Air Arm. Development of the Sea Fury proceeded, and the type began entering operational service in 1947.
The Sea Fury has many design similarities to Hawker's preceding Tempest fighter, having originated from a requirement for a "Light Tempest Fighter"; both the Sea Fury's wings and fuselage originate from the Tempest but were significantly modified. Production Sea Furies were fitted with the powerful Bristol Centaurus engine, and armed with four wing-mounted Hispano V cannons. While originally developed as a pure aerial fighter aircraft, the definitive Sea Fury FB 11 was a fighter-bomber, the design having been found suitable for this mission as well.
The Sea Fury attracted international orders as both a carrier and land-based aircraft. It was operated by countries including Australia, Burma, Canada, Cuba, Egypt, West Germany, Iraq, and Pakistan. The type acquitted itself well in the Korean War, fighting effectively even against the MiG-15 jet fighter.[1] Although the Sea Fury was retired by the majority of its military operators in the late 1950s in favour of jet-propelled aircraft, a considerable number of aircraft saw subsequent use in the civil sector, and several remain airworthy in the 21st century as heritage and racing aircraft.
https://en.wikipedia.org/wiki/Hawker_Sea_Fury
OP
5 Feb 2006
UPDATE TWO
I spent a few hours getting the cockpit together, starting with XF-69, NATO Black all over. The seat cushion was painted XF-49 Khaki.
This was sealed with a satin varnish and the PE applied as per the Eduard instructions. As always, some of this was very tricky, especially all the little handles and levers.
Weathering was achieved with the use of MIG Ammo wash, Grey for black (A.MIG-1615).
OP
5 Feb 2006
UPDATE THREE
Been a while since i have posted on this build.
Basic assembly was all wrapped up with minimal fuss. Seam lines dealt with a few spots of Mr surfacer 500 was needed.
After a good clean with IPA badgers black primer was used and any further defects dealt with.
Tamiya xf-2, white was then used to highlight panel centres and marbling effects.
Then the underside was painted with thinned MRP-118, Sky and once dry, then masked off.
Then the topside was sprayed MRP-114, extra dark sea grey.
Before removing all the masking, the U/C bays were painted with tamiya xf-4, yellow green with some white added to look like the hawker yellow used originally.
Then the decals were applied with relative ease using set/sol and once dry, i utilised a used airbrush needle to then ensure the decals were in the panel lines where needed.
Once the decals were all dry and seated, 2 coats of alclad aqua gloss was applied, ready for weathering.
OP
5 Feb 2006
UPDATE FOUR
A Flory models dark dirt wash was applied all over the model and once dried, the excess was removed.
Left for a day, I decided some Tamiya semi-gloss clear today as the next stage.
This is what happens when you forget to put the cover on the colour cup....
OP
5 Feb 2006
UPDATE FOUR POINT ONE
So, repairs started with using tape to rip the decals off which was somewhat satisfying.
I have a spare decal sheet (long story there)...
Then affected paint which was more widespread than initially thought, was rubbed down and polished to make it as smooth as can be for now.
Any dust was cleaned off with a damp piece of kitchen roll.
OP
5 Feb 2006
FINAL UPDATE
Finishing touches added with canopy, U/C, U/C doors etc and then i used some oil paints to blend some subtle exhaust stains.
I have always struggled to do exhaust stains with an airbrush so oils seemed to work well.
