Hi
I have an Asus Rampage Formula With a QX6850 Extreme CPU @ stock (3.0GHz)
4GB PC8500 Crucial Ballistix DDR 2
2x WD Raptor 150 in Raid 0
HIS Radeon 3870x2
Coretemp @ Idle (i.e. as I'm writing this, PC has been on an hour or two) shows 49 47 46 46 for each of the four cores respectively. The CPU cooler is a Tuniq tower, and my Case fans are 4 (space for a 5th but drive cage not fitted atm) 80mm Vantec Thermoflow fans and a 120MM Vantec above the PSU. Now I know the 3870X2 is a heat monster and from having the side off, the CPU temps are a few degrees lower, is there anything I can do to improve things slightly (not that I'm having problems at all... just wondering.
Fan air Directios are in/up (Front) and Out/Down (Rear)
thoughts ?
Andrew
HIS Radeon 3870x2
thoughts ?
Andrew
At the moment its just "plugged in to get everything working", so isnt great, and I've notriced that with the tuniq installed my 2 12v (4 pin adapters) are a bit of a squeeze around it to get them plugged in. Power Supply is an OCZ GameXStream 850w, but mahy have to change as it only has 2x 6pin PCIE connectors, if I ever want to put a sxecond 3870x2 in I'd swap it for one with 2x6 and 2x8, but thats in future.
